Oldfart
- Joined
- Oct 21, 2017
- Posts
- 6,087
- Reaction score
- 15,231
I don’t have any firsthand experience. I know people with them and they love them. They look good. If you get them in the same size tire as the stock KO2 the you would be increasing unsparing weight of almost 8lbs per wheel. Probably change the performance a bit.time to replace my KO2's , only have 26k on them they did not wear well, thinking about the Nitto Ridge Grappler, any feedback on them ?
How do you like the 601’s? Those were what I initially wanted but decided against that big of a wheel. Sure do look good though.I'm running 37 Ridge Grapplers on 20" VenomRex 601s. It's definitely stiffer than stock, but I need to reduce my tire pressures some. Winter in central TX is ridiculous with the daily temperature swings, so keeping cold pressure consistent is a little tough.
I'm only about 10k miles in, but thinking of something like 37 KM3's with 17 or 18" wheels once the RG wear down.
I've had both RGs and KM3s in 37". KM3s are vastly superior on every surface. RGs are more quiet when new, but when worn get louder. RGs will last longer because the tread compound is softer on the KM3s, but if traction is paramount, go with the KM3s.I'm running 37 Ridge Grapplers on 20" VenomRex 601s. It's definitely stiffer than stock, but I need to reduce my tire pressures some. Winter in central TX is ridiculous with the daily temperature swings, so keeping cold pressure consistent is a little tough.
@Beinkounter are those Vapors? How do you like them? They are pretty heavy from what I remember reading before. They look sharp though!
