GEN 2 Wheel lug nuts - mine 22 mm
Ski4Ever
Denver, CO
Any reason you didn't order these instead? Same part number, but about $47 cheaper.
comes in a 40-pack
6 bolts x 5 tires = 30
What do I do with the extra 10? lol
I think you're going to end up with an extra 16 (6 bolts x 4 tires), aren't you? The spare tire doesn't have lug nuts on it (or maybe you've got an aftermarket bed mount that uses them...)
hedonist222
hedonist222
Dubai, Abu Dhabi, UAE
The CJ pony are 24 pack
the amazon is 40-pack
Ill change out the spare ones as well
So 5 tires x 6 bolts = 30
The spare tire is basically sitting in a furnace between the bed heat and the tarmac heat.
Temps here in the UAE reach 55 celcius for 2 months of the year (ill let you convert) and even 65 for 2 weeks of the year - ambient temp.
Ski4Ever
Denver, CO
Again, unless you've made some sort of modification, there are NO lug nuts on the spare tire, though! So you still only need 24.
Fordraptorrrrrrrr
Idaho
Yep, get em off as soon as you can and replace. I had to dremel the caps off a few of mine. The caps will get bad enough where they will just spin on the actual lug.
Thanks I just ordered these in preparation for my oil change and tire rotation I'm going to do next Sat. Been hearing that the factory lug nuts have been an issue, glad to get it taken care of.
hedonist222
hedonist222
oh yeah
wheel seated on tire
and re-use replaced-tire bolts
ok
now I have 16 spare bolts
no matter
I'll eventually swap out deformed bolts as they devolve
