What springs to run on Gen 1 with Gen 2 shock and bucket conversion?
ograptor
Masshole
Sdhq has Gen 1 spring perches listed at 55 bucks a piece. Maybe give them a call and see if they have or can get them for the Gen 2 shocks
TomDirt
Hesperia CA
Kartek also carries the Gen 1 spring perch, but neither has the Gen 2. I'm going to keep hunting for used ones, even if I have to get one at a time.
2012SCSVT
CA
Are you abandoning the svc collars just because you think they will hit the axle or have you confirmed your set up?
TomDirt
Hesperia CA
The internet says they hit Trackmotive axles, but the bigger dia Gen 2 coils definitely hit the tubular UCA's. Plan B is to use the old Gen 1 coil spring with a short RPG lift collar. Hopefully I'll have Gen 2 dampening & travel, with the Gen 1 spring rate, and it definitely needs a limit strap. I just ordered Icon's Gen 1 leaf springs today; already installed the KHC rear shock mounts and Gen 2 Fox 3.0 rear shocks.
2012SCSVT
CA
Copy, okay well they did hit mine but like I mentioned I have modified my shock and shock geometry. So you may be good on the axle side, it's worth checking.
TomDirt
Hesperia CA
I also really want to get UCA's that can be aligned in place (& get rid of that lower arm alignment setup); so right now the billet ones are the only option. As usual, the correct answer is spend more,money
2012SCSVT
CA
I would recommend keeping the slots personally. It's such a pita to have an alinement done on uppers alone.
I ended up welding the alinement cam bases to the lower mounts and it makes alinements quick and easy and the guys can get it precise. I have not had an issue or a slippage.
I domt really have a good picture on my phone but you can see it here:
96,796
60,771
cristiansthee1
