What did you do to your Raptor today? (Gen2)
zemuron99
Seattle
Transmission fluid drain/refill and a filter change, and a t-case fluid exchange. 28,440 miles on it. I'd long planned on doing this 'refresh' around 30k miles, but I'm not driving as much as I used to these days, and I had a stretch of days off work, so I took advantage of them before the garage turns into a refrigerator.
Some thoughts on the process:
1. This isn't for the faint of heart. It's not complex, but it's not that straightforward, either. In all it probably took me about 5-6 hours, but I'm slow, was working at ground level, and spent a lot of time planning the next step. Yes, I watched some of the you-tube vids beforehand, but watching a vid and wrenching under your truck are truly different. I know a lot of you could have done it a lot quicker. Even raising it on jack-stands might have helped, I dunno.
2. Most if it is a one-person job (remove rear-most skid plate for the tranny, and the silver L-shaped plate for the t-case, heat shields, pan bolts, filter exchange, reinstall pan, refill, check level, and put it all back together.), but man, when it comes to actually dropping the pan, best to have a buddy with you.
2a. Some of the heat-shield bolts may take the entire stud out when you remove them. It's really not an issue for the two on the sides, but it's a bit of a pain for the two on the rear, since they're right over the exhaust crossover. Fortunately, the heat shields are little more than stamped aluminum, barely thicker than foil, so they can be re-shaped to wiggle the studs around the exhaust.
2b. It would have been really nice if Ford could have routed the lines to the transmission cooler just a half-inch further forward. As it is, the lines catch the passenger side corner of the pan, and when you 'pop' it past them, best to have your catch pan at the ready because the front of the pan will drop however far it can and the remaining 4+ quarts will come a-pouring out. This is where the buddy would help to either help you hold the pan steady, or manage the catch pan.
3. Mine was fully filled from the factory. I know some early gen2 owners had under-filled transmissions, but when cold mine was right up to the bottom of the "C" hashmarks on the dipstick. That was my goal when refilling it. I never had the courage to a check at full op temperature (until now, see below).
4. It took about 7-1/3 quarts to refill mine. I filled it with about 6 until it was between the "A" and "B" on the A-B-C dipstick. Then I started it and cycled through the gears like you would for a 'hot' check. When I rechecked it, the level was below the "A" so I added 1/2 quart at a time until it was just touching the bottom of the "C" range (cold). In total, I put in 7-1/2 and when I checked it at operating temperature, the fluid level was just above the 'C' mark, so I took about 1/4 quart out and that put it just at the top of the "C" range.
5. I put on a new gasket, but the old one looked perfectly fine. But, as long as I had the new one, and it's not too pricey, decided to just go ahead and use it for peace of mind.
6. The transmission fluid didn't look too bad, it was definitely darker then the new stuff, but didn't smell burnt at all. There was a very fine sheen of silvery metal in the bottom of the pan and along the magnet, but nothing close to what I would call a large amount.
7. The fluid from the T-case was surprisingly dark (see pics in the post below this one). Probably 10-15% of the miles have been in 4wd, including at least 20-25% of that in 4-lo, whether I really needed it or not. But I wanted to 'wear in' the underdrive gears as much as possible before this first change. I know the LV and ULV fluids have a reputation for darkening pretty quick but the darkness of the t-case fluid really surprised me. There also seemed to be a bit of a silvery 'sheen' to this as well as I transferred from the bucket into the disposal containers.
Pics:
zemuron99
Seattle
A couple of more pics. New and old filters side by side, and a few drops of the t-case fluid on some newspaper.
Hagasan41
Florida
Nice job @zemuron99. Thanks for sharing the photos. I‘m planning to tackle my transmission fluid but it looks to be a bit of a pain so I’ve held off as I don’t want to do double work. Currently researching upgrading the pan to a larger one with a drain plug to make spill and fills a bit easier.
zemuron99
Seattle
yeah, I get that, Hagasan. I'll probably do another drain/refill (no filter) at 60K or so, though it's also tempting to let it run to 100k. Depends on if I get the RV trailer or not. If I'm trailering, may do them every 30-50K and I'll put on an upgraded pan w/the second one when I'll do the filter as well. Since it's only a once-every-few-years kind of job, I wasn't strongly inclined to invest in a new pan just yet. Plus, with the limited air flow through that area w/the skid plates and all, not really sure a finned pan adds much more cooling. If cooling ever becomes a concern, I'll add an upgraded cooler up front. But, having a drain plug sure would be nice when you're not doing a filter change!
J R
South County
2019 Screw
RPG Billet UCA
RPG Billet Tie Rods
Fox 3.0’s all around
+3HD Deavers w/ drop shackle
SVC Intercooler
SVC Bump Kit
SVC Bumpers
(5) Method 305 on 37 KO2
Baja Designs Squadron Pro’s (bumper) and XL 80’s (A pillar)
Magnaflow Catback Exhaust
Tires, Wheels and A Pillars go on next wk!
Todd Turbo S
Nor Cal
Found these unique wheel locks, Advanced Wheel Locks, they are made 100% in the USA and claim impossible to remove their wheel lock without their key. A bit pricy, but my initial thoughts are great quality, Hefty feel and the finish is like jewelry. I stumbled on these as I was researching the Tesla Forum for my wife’s new Tesla and they were raving about them. Bought two sets for two of my other vehicles and waiting for their Tesla Wheel Locks they are on back order. No affiliation, but here’s the website in case anybody is interested in purchasing a pair or reading about it. https://advancedwheellocks.com/
Danactive
I'm Back!
Syracuse, NY
Installed SPD TSTAT which fixed my no heat issue thank god and new one step colder Ford performance plugs. I have to say I love who ever designed the plug accessibility on these engines. My Tacoma was a nightmare to do plugs. This thing took me 25-30 minutes tops and that was holding a drink in one hand and a wrench in the other lol
96,484
60,438
BayCityBomber
