What mileage are you at now?At what mileage should you change the differential fluid?
TYVM, this is 100%.FYI - Dorman covers are $99 at Rock Auto.
Time = Money, plus you don’t need to replace the gasket at $27 per fluid change ever again. I’m replacing the cover next month. Every performance diff I’ve ever had to drain & refill had a drain/fill plug. No way I’m dropping the spare, pulling that cover off, and the 12 bolts, and scraping the surface and replacing the gasket and retorque-ing the 12 bolts when I can simply remove 2 plugs.
I’m all for doing-it-yourself……I’m just against doing it the long and hard way with zero benefit. In this case $99 one time saves me $27 + easily an hour worth of labor every time after.
I mean, I'd do it every 25k or so just for fun. With a cover that has a drain plug, it takes like 10 mins?At what mileage should you change the differential fluid?
Just over 38kWhat mileage are you at now?![]()
Slightly different casting than the FRP and Spicer.this cover is the same as the spicer/FRP cover? looks similar
