What did you do to your Raptor today? (Gen2)
jAKe47
Georgia
Installed the Morimoto XB headlights. Santa came early! Love having DRLs now. I was freaking out for a bit. I had one connection that had no mate. I found an old post on here where someone asked about the same connection, but never got a response. So, I just went ahead and ignored it, everything works, the DRL, Bugatti start up sequence , sequential turn signal and of course the headlight, all 4 LEDs light up on low beam.Thanks Nick @ApolloOpticsView attachment 433996View attachment 433997
Hopefully those are easier to aim than the Morimoto's I had on my 2010 Platinum. You couldn't reach the adjusters with the headlights in. Any little tweak you wanted to make you had to take the whole assembly out and then put it back in and test again. Major PITA.
Sig Fanboy
WV
It looks like there is a bolt that I can get a ratcheting end wrench on to adjust. It cautions not to go more than 3 revolutions in either direction
Zeusmotorworks
Law Enforcement-Fire
Yes sir. Here is an old picture, pre Kings.
Jelly of the whole setup. Need to get off my ass. Been running CO2 for bout a decade and a half or more... SO DAMN WORTH IT! Or some other high pressure gas vs pumps!
Old-Raptor-guy
USA
You are missing out on more hοοκεrs and blow while some $10 pump refills your 37s!
So true, on the old 2002 F350 going from 25 to 65 psi took right about 35 minutes with an ARB compressor. Less than 5 minutes with CO2 (for all 4 , 1 at a time)
Never used compressor on Raptor, from 17 psi to 33ish psi is about 40 secs per pair of tires. (Home made set up doing 2 tires at a time.
