Geo_Tactical
Andersen WDH goes with Raptor like PB&J
Sent from my Galaxy Note 8 using Tapatalk
Just saw this. Glad you got it worked out before I wrote a novel. Setting up a WD hitch can be a pain.I got everything working. For those that are interested - my tongue weight is 650lbs per the Sherline scale. I used 5 washers on the hitch and left the L-brackets in the center position. Trailer is almost exactly level, about 1/2” nose down when the suspension squats. Front wheel arch height is same as unloaded, rear is 1” down from unloaded. The 5pm rain showed up at 10:30am so no pictures.
I took your advice and just centered my L brackets...Im now thinking I will remove 2 washers and go back to 5. Do you have any photos?I found getting it all hooked up and then driving it before remeasuring worked to overcome the Live shock issue. I was also careful to measure at the same spot each time with a straight edge.
