Warning for those with Fox 3.0s or 37s
ntm
Alberta, Canada
I apologize gentlemen, you are all correct. I some times don't think before I just start typing away, I do that way to often.
I know we have IWEs and they are vacuum activated.
I had my 84 full size Bronco in mind. I always wanted to put lockers in the front to get a true 4 wheel drive.
Truck rusted out before I do anything with that. LOL
In any case I was told by a few techs that in 2011 Ford changed something in the Raptors IWE, what I don't know.
They also changed the rear with bigger parts, pinion, shafts, bearings. I just wonder what they did to the IWE?
And I did not realize (or forgot) they started in 2012 with the front locking diff.
Now, why was I told that I wouldn't have a problem launching in 4x4 in my 2010 1/2, even with 560 rwhp when it comes to the IWE,
transfer case I will wear out faster especially the chain.
I have been doing 4x4 launches for over three and a half years probable over 200 if not more.
I get the two rear and front divers side to spin for a second or two when taking off.
I mean that has to be harder on the IWE then pulling a tree stump, unless the wheels were turned.
I only do straight line take offs and I make sure I roll forward a bit!!! to lock everything, that's a habit I've been doing for all my 4x4s.
So far knock on wood I haven't had an issue.
Spinning is easy on things, traction is bad.
The weight transfer helps unload the front drivetrain.
Offroading is harder on the iwe's, I've got less horsepower and broke seven of them before giving up on the 4wd completely.
The only thing that's changed on the iwe system over the model years was a slightly updated vaccum solenoid.
Modified or not, it's a weak point.
