Vorsteiner Venom Rex 601 Questions....
Nick@Apollo-Optics
Curious if anyone has tried these wheels with geisers and 37” Ridge Grapplers?
You're going to have to do some trimming.
We've fitted these wheels on Nitto Ridge Grapplers in a 325/60/20 and still have rubbing at full lock with RPG Adjustable Spring Perch collars set at 2 5/6" of heigh increase.
turn-r-us
What would you have to run on 20s with stock truck to not rub on daily driving?
Do you know how much the rolling diameter changes in comparison to stock wheel?
Nick@Apollo-Optics
You'll want to run a 35x12.50x20. If you run a K02, it's 0.2" taller than the OEM 315/70/17 tires. With a 35" tire, you'll only get slight rubbing at full lock in reverse on stock suspension. If you add a pair of spring perch collars, you'll eliminate the rubbing.
