iSurvive
Tips:
- it is actually two layers of plastic to drill through, remove the small carpet piece at the bottom of the console (it's just laying there), then drill a 1" whole thru the plastic, then drill another 1" hole in the layer below that
- watch Noah's or anyone's video on how to remove the center console (you don't need to completely remove it, but enough to lift the backend up to get your wires to the hole you drilled
- you will run your antenna wire, power wire, and optional speaker wire thru the hole. The speaker can be mounted under a front seat, the antenna wire can go under the rear floor mat and out the back of the truck thru the vent behind the rear seats, the power can run along the bottom of the console, up into the dash, and then thru the firewall.
- I also ran a LAN extension cable from the microphone jack thru the hole and under the driver's seat. Then I mounted my mic on the dash and plugged it into the extension cable.
-I think I screwed up my rear A/C by drilling the holes, because now no air comes from the rear vents. I still haven't invetsigated the issue fully. I might need to plug the holes enough to keep the air from escaping.
So good news, my rear a/c vents are working now. I reseated the console when I installed a new VHF antenna wire and all is well.
