RGVRaptor
This just started happening yesterday and haven't quite figured out what's causing it, but I believe I've figured out how to stop it when it starts.
This has happened 4 times already: From a dead stop I will start going and will hear a grinding/scraping/friction noise coming from the transmission. It almost sounds like the brake caliper is scraping against the rotor, but a lot louder and worse.
It speeds up and gets louder when I accelerate and stops when I let off the gas. It will do this for however long it wants then I will hear a loud *CLUNK* in the transmission and it will stop.
The last time it did this I pulled over, switched to 4H, then to 4L, then back to 2WD and the noise went away which leads me to believe it has something to do with the 4WD.
Anybody have any guesses on what is happening and why the truck seems like it's trying to switch from 2 to 4WD on it's own (or something)... This is disappointing as I've only got 8k miles on the truck and have had it less than 1 year.
Thanks in advance!
EDIT: It's been very rainy and wet here the last few days. Not sure if water might have splashed up underneath the truck and got to a sensor on the transmission or something...
Thanks in advance!
