I have a set of VenomRex 601's Carbon Graphite 20" +12mm offset with OEM TPMS sensors
with BFG KO2's 35 12.50 20 E rated tires
Mounted and balanced, under 600 miles on set, installed 4 weeks ago.
I had the wheel weights painted black to blend better with the wheels.
No lug nuts included I re-used them, center caps are the plain stock pieces, not the pictured ones with red inserts.
No nicks, dings, marks, patches, plugs or modifications.
Recently swapped to same wheel in a different finish is reason for sale.
Located in central Virginia, zip code 23112.
$2750 local pick up!
Newest 601's just for reference on Avalanche Gray
