vendors, i need a bumper
The Car Stereo Company
here, on frf
i was estimating (give or take) $2500-3000 for a setup. i guess i should call some vendors when i have more time. i have no time whats so ever..... what the hell am i talking about....
MB RAP
N. CA
You would have had time on Saturday night if we would have just took the highway and went home...and probably not wanting a winch near as bad either. haha.
---------- Post added at 12:19 PM ---------- Previous post was at 12:18 PM ----------
I've been looking at winches today too!
Netix
Banned
Ontario, Canada
ok so busa isnt a hardcore offroader he dont need a winch front and back.......
the easiest thing then is winch plate, winch and then a adapter for any bumper you use...
plus whats there to winch from as a base in the desert???? more likely you just need a anchor winch and your set.
dont need a winch when you go wheelin with buddies... thats usually your best bet is to not go out alone.. even winches can fail been there done that...
when the time comes and i mount my 2 other 50" led bars.... ill be getting a winch but sure as hell not a electric one...... ill be getting a hydraulic winch. seen to many electric winches fail here in our terrain
ruffstuff
Ouch! LOL
I'm looking also. Probably going the receiver hitch route as I don't want to add 100 lbs to the front end permanently.
Icecobra
Gilroy Garlic capital of the world
Winch and winches which winch and why
Ouch! LOL
You could do this it only adds about 60 pounds permanently..
Icecobra
Umm yep the hitch is 60 pounds... the winch is about 80 pounds ... its the warn cradle and a superwinch 9500 ... I went with the rope instead of the steel cable to save weight.. But yes the part that bolted to the truck is about 60 pounds... But I ahve never seen a winch mount bumper under about 200 pounds so I figure from strictly weight I am ahead...
---------- Post added at 04:52 PM ---------- Previous post was at 04:46 PM ----------
The base plate is 3/8 High strength steel, 3X5 structured steel welded in one beed all the way around with 1X2 structre steel welded to that to create a shear reinforced from side to side winch effect then pwder coated... 60 pounds total weight with grade 12.9 bolts to frame...
