DegenRaptor
Socal LA areaClean rig. Where in CA is it located?
What are resister pellets, sounds like gerbil food?If I were you; the spark plugs, wires, boots and new resister pellets; then move on to all drivetrain fluids, and maybe the Ujoints & yoke seals. Just a start and in no particular order unless you find it needing attention right away.
¿Ru being serious, or just messing w/me? They are the little gerbil looking pellet in the ignition coil. Unless he is getting a misfire and or a bad coil code, it’s still a good and easy replacement. The boots being that old get brittle and can split easily when you pull them to replace the plugs, and if you don’t catch it may cause electrical shorts, etc.What are resister pellets, sounds like gerbil food?
I wasn’t messing with you, didn’t know you could replace pellets, thought it was plugs, wires and coils. Never heard of pellets, can’t be the only dummy on the forum. LOL, I come from a place if you don’t know something, ASK, otherwise , how you going to join the smart guys¿Ru being serious, or just messing w/me? They are the little gerbil looking pellet in the ignition coil. Unless he is getting a misfire and or a bad coil code, it’s still a good and easy replacement. The boots being that old get brittle and can split easily when you pull them to replace the plugs, and if you don’t catch it may cause electrical shorts, etc.
No problemo, my a Canuke brother…and like Mr. Porter mentioned, search and you shall find these and other maintenance threads. My tips were made as a starter set of easy things to work on for the DIY and save himself a little mullah.I wasn’t messing with you, didn’t know you could replace pellets, thought it was plugs, wires and coils. Never heard of pellets, can’t be the only dummy on the forum. LOL, I come from a place if you don’t know something, ASK, otherwise , how you going to join the smart guys![]()
