UPR Black Dual Valve Oil Separator for all 2017 3.5L EcoBoost F-150s and 2017 F-150 Raptors.
UPR knows what they are doing when it comes to aftermarket catch cans and this UPR 5030-221-1 Black Dual Valve Oil Separator for your 2017 3.5L F-150 EcoBoost or Raptor proves that beyond a shadow of a doubt. The Ultimate Oil Separator features a UPR Plug N Play™ Dual Valve Catch Can with UPR Pro-Series Check Valves one way electronic pressure sensor system to deliver improved fuel economy, throttle response and performance.
Features and Benefits:
- High quality T-6 6061 CNC machined billet aluminum
- Plug N Play ™ fittings all the way around catch can
- 16oz capacity can (6" x 3")
- Show quality finish
- Nickel T fittings and drain ****
- Prevents oil from entering intake
- Patented multi-chamber design traps oil
- Improves fuel economy, throttle response and performance
- 5/8" oil resistant continental braided hose included
- Black color scheme
- Require drilling your factory inlet for the WOT connection
- Easily installs in 30-40 minutes
Manufactured from Domestic T-6 6061 Aluminum bar stock and finished off using only the best Diamond cutters, UPR's 5030-221-1 Black Dual Valve Oil Separator exceeds your expectations of what a superior product should fit and look like. The fittings and drain **** are manufactured from Nickel T. Along with all the hardware you'll need for installation, a 5/8" oil resistant continental braid hose is included.
Order this UPR 5030-221-1 Black Dual Valve Oil Separator for your 2017 3.5L EcoBoost F-150 or 2017 F-150 Raptor today from CJ Pony Parts.
