DTF-DEUCHER
Has anyone upgraded the upper control arms, i read it helps when your up there on the top perch. Is this true or is it just a rumor?
We offer a uni ball upper arm that is designed for the guy who wants to run the 2nd and 3rd perch. here is the link.. Arms and tie rods are a must!!!!!
A arm link. ORP 1" UNI Ball Upper A Arm W/ Heims
Tir rod link. ORP Heim Steering Tie Rod System. 7075 aluminum 1-1/4
Call us if you have any questions 949-581-5001
Yes good question. We rotate the uni ball cup so it won't bind up at full compression or droop. It's designed for the 2nd and 3rd perch adjustment. The raptor is aligned from the bottom arm so using heims on the top will stop any side to side flex in the mount. Bushings will allow for movement and will wear out faster depending on how much use your raptor gets.
is that going to require your shop to do the install? or can it be done on the opposite side of the country fairly easily by a competent shop? (like 4wheel Parts) The east coast isn't prerunner mod friendly.
