Rhinoman
I have a used 2012 gen 1. Previous owner had 2 led lights installed in the lower grill next to my winch lead and wired to upfitter switch #1. But…..one just went out and I’m going to replace them with some bd squadron pros.
My problem is how they are wired. They are using switch 1, the proper fuse works, but they did not wire them through the upfitter wiring in passenger foot well or through firewall. It appears that they tapped power directly to a wiring harness located on the drivers side of the engine compartment near the firewall.
I didn’t know that was possible. So is it safe to reuse their power pick up?
I have checked all the upfitter wiring and switch. Nothing has been altered or used but the switch works and it’s running through the correct fuse. Help!!
