AUX power is in different place in new Raptor
Others may have discovered this already, but the AUX wires are set up differently in the new raptor. The power AUX wires are under the hood on the left hand side (facing the front of the truck). You can wire directly to these for lighting and other external connections. If you want power and connection in the cab (radar detector, camera, etc), then you will need to connect the left side wires under the hood to the ones immediately to the right - - the colors obviously match up. Then, you connect your interior connection to the wires inside the knock out panel on the passenger side below the glove box. In the original model, the power was in the knock out panel and the pass through had to be connected for lights, etc. - not the case in the new raptor. Much easier and the wires are much easier (and longer). I posted some of this in a thread on wiring a detector, but thought it might be helpful here as people are looking for AUX wiring help..... here are a couple pics of the AUX wires under the hood and in the knock out....(note that these pics have my radar detector connection to AUX 6 done, so I had to connect the under the hood AUX wires for the pass through).
