ultimate driving light combo?
Speeddeacon
NC
will the LVJ relay make it easy to make the SAE's come on with my low beams?
Yes, you just have to tap into low beams rather than high beams as the secondary switch. If you have your low beams coded to run as DRLs, like I do, you’ll want to make sure you have the upfitter switched off during the day, unless you want them to run then too.
Jeff Boone
Jeff Boone
Memphis TN
If I buy the three light bumper kit with SAE, Pro Driving Combo, and Pro Spot, will part of the light from the SAE's be lost due to the mount/shape of the bumper itself? The SAE's are probably the most important lights of all because they'll get the most use.
I may also get the ONX6+ as well. If I do, would you change the make up of the bumper lights. Also, what beam pattern would you recommend for the ONX6+?
4x4TruckLEDs.com
Nope. With the SPP Triple Fog Light Kits no lights get blocked. Here is a great example of a customer running a similar setup:
Jeff Boone
Jeff Boone
Memphis TN
Awesome!!! If I go with the ONX6+ as well would you change any of the bumper lights? If not, what beam pattern would you recommend for the ONX6+? My main objective is to have as much light as I can get beneficial use out of with my low and high beams on the street. (understand the risk of running the Pro Driving Combo's automatically with my high beams)
ps. Thanks for staying up so late and answering questions!!!!!
4x4TruckLEDs.com
4x4TruckLEDs.com
I'm trying but everytime I get up to walk away from the PC i hear a message come in.
Overclocker
As Neo pointed out Baja is re-tooling the SAEs right now so they'll be tweeked slightly in the next few weeks to improve on their compliance. But they have a much better pattern when used as daily fogs then the Squadron Wide Cornerings, that's for sure.
How are BD vendors handling the re-tooling the SAEs if we order during the rebate period? E.g., are you shipping current units, do we send them in for updates, or will there be a retrofit kit?
