TSB 11-4-14
04/27/11
IKT OR IA - INABILITY TO UNLOCK DOOR -
POSSIBLY INTERMITTENT - BUILT BETWEEN
7/1/2010 AND 1/26/2011
FORD:
2011 Edge, Explorer, F-150, F-250, F-350, F-450, F-550
LINCOLN:
2011 MKX
ISSUE
Some 2011 F-150, F-Super Duty, Edge, Explorer and MKX vehicles built between 7/1/2010 and 1/26/2011, may exhibit an inability to unlock the door(s) using the integrated keyhead transmitter (IKT) or intelligent access (IA) key. This condition may be intermittent.
ACTION
Follow the Service Procedure to correct the condition.
SERVICE PROCEDURE
1. Follow updated Workshop Manual (WSM), Section 501-14 for tire pressure monitor (TPM) diagnostics in the Remote Keyless Entry system.
2. If diagnostic routine leads to replacement of TPM module, follow WSM Section 204-04 for removal and installation of 1PM module.
NOTE SUSPECT PARTS HAVE BEEN REMOVED FROM SERVICE STOCK. REPLACE WITH EXISTING SERVICE STOCK.
WARRANTY STATUS: Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT : Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATION DESCRIPTION TIME
MT110414 Use SLIS Operations If Actual
Available; Claim Additional Time
Diagnosis Or Labor
Performed As Actual Time.
DEALER CODING
CONDITION
BASIC PART NO. CODE
15K602 01
04/27/11
FORD:
LINCOLN:
2011 MKX
ISSUE
ACTION
SERVICE PROCEDURE
Diagnosis Or Labor
DEALER CODING
CONDITION
BASIC PART NO. CODE
15K602 01
