Transmission updates - aftermarket pan and dipstick?
TomDirt
Hesperia CA
Did you need to pump the fluid through the extended dip stick with a mityvac-type device or something else? (I recently screwed up mine from using it to drain old gas, and now the rubber seals in it are messed up.)
BTW, new oem leadframes are now cheap & in stock!
C
Cody Templeton
Des Moines, IA
Nope, just used one of those regular transmission-style funnels and filled it up like you would any other vehicle that has a dipstick you can fill through. I did use a bungee cord to hold the funnel so it didn't fall, but that's it.
