91Eunos
My transmission woes (and cam phaser replacement #4) are already discussed in other threads, so I won’t rehash all the reasons and events that led us here… My new 2-post lift will (hopefully) be delivered and installed next week, and my first ‘big’ project in the new garage will be a cab-off R&R of the motor and transmission.
Will also upgrade the turbos, intercooler, exhaust, etc. while I’m in there.
Have a plan brewing for the motor, but still not 100% sure whether I’ll just buy a complete transmission to swap (faster turnaround), or have mine rebuilt. Leaning towards the later, and going with ATS up just NE of Dallas.
My question is: Will I need to do the Ford IDS programming and a transmission relearn if I’m rebuilding/reusing my own transmission?
All the clutches, and the C/D/F housing will definitely be replaced/upgraded, and likely the valve body and torque convertor too. I assume that the relearn will be needed if I do the valve body, but honestly don’t know.
@FordTechOne Any input appreciated. Also, is this something a Ford mobile tech could do? I’d really like to avoid a tow to the dealership for programming after doing all the actual mechanical work here.
