Transmision gear indicator
c-ne-elk
El Paso, Tx
On the right side of my dash screen, mine used to display (vertically) what gear the transmisson was in (1 - 6) but no longer shows this. I would imagine I have turned something off but have serched the owners manual and can find nothing in it. Anyone know how to turn this back on?
toadman
I'm not aware of any way to turn this off. sounds more like something came unplugged.
c-ne-elk
c-ne-elk
El Paso, Tx
I just went out and played with it some more. While leaving it in drive and sitting still, I used the +/- button on the side and it came back on. Hmmmm.. working fine now but seems strange to me.
RatedSVT
Sleepy Hollow,IL
You can turn off & on, the 1-6 by playing with that +/- button while in drive. I usually keep it off unless im wanting to play in manual mode. I notice too if you leave the numbers lit up only to a certain gear while in D not in M. That the truck won't go pass what the last number is. For example it's a 6 speed , so if you have the numbers showed up to number 5_ then it won't shift into 6th.
Humvee21
Normal. What happened was that you probably accidentally hit + while the gear limiter was on 6 already. Thus, removing the indicators.
Blind1
Central Alabama
I noticed my wasn't displaying when I picked up my truck yesterday from the stealership. I'm glad you posted this. I thought I was seeing things.
NickPic83
Rockland County NY
Yeah the while in drive the + will display the gears. If u keep hitting the - it will lock out gears which is nice if u wanna downshift goin down a hill u don't have to go to manual mode.
Sent from my DROID RAZR using Tapatalk 2
Dane
Littleton, CO
Same deal on mine. I swear occasionally it just turns off the display on its own. Just pressing the + brings it back. It hasn't done it in a while though, maybe I was just hitting the damned thing and not noticing it. I don't know why, but I kind of like having the gear displayed even if I'm not in manual mode.
