Tranny fluid no dipstick?
nogm4me
FL
Is the transmission non-serviceable? I was thinking of adding a cooler, but when I looked for a dipstick there was none. I read in the manual that the tranny shouldn't need service for 150K. I understand the deal with FMC not wanting to cover mess-ups on fluid selection, but what if you wanted to add a cooler or flush you own? I've done the R-4100 many times on the 7.3's and is really easy.............only takes 5 4 gallon jugs. Can we not check or add fluid to this tranny?
Hockster
My 45ft Bluewater Party
Winchester, Va
Ha ha ha. check hot while idling in park laying on your back with arms over head... Its just that simple!!! ******* cost cutting and warranty reduction groups
pirate air
will plunder your booty
Oh, and don't mind the catalytic converter that's in the way.... It's only glowing at roughly 4748205768302 degrees. It's such a ****** design.
nogm4me
nogm4me
FL
Pirate Air, from your experience if it is a poop design, is it still a good tranny? I am impressed with it so far. Dave
pirate air
The transmission itself is built stout. The shift programing is a little whacky and the electro valve packs have problems in some of the early models. So far havent seen any catastrophic failures.
nogm4me
nogm4me
FL
I'm coming from a ZF 6 speed 7.3L and this transmission seems to downshift when slowing with my foot off the gas..........like it is doing a "manual" downshift. I'm also pretty impressed in 6th gear with 4.10 gears the engine is turning @1,500 RPM @55-60mph. I haven't really put the hammer down yet.
