TPMS warning fix
OKflyswatter
Oklahoma
Mine has done this from the day I drove it home and it drives me nuts. I hate using the dealer in my town, but my problem is that I have to work so much that I don't have the time or energy when I get home to get into this myself. I will show this to them and I'm sure they will ignore it. On a side note, DougDimmadome I love the killdozer note! Is that a bumper sticker and where did you get it?
ofcbarbrady
VA
you dont NEED to. I did the work myself in about an hour. Hasn't come back since I fixed the radio situation.
Sorry I meant we need the BEAD for the fix, not the dealer. I tried the RFID blocking material and it didn’t work. My sensors went off like clockwork at 20 miles. Zero issues since installing the bead
DougDimmadome
DougDimmadome
East PA
kirkb
So Cal
Any tips on getting the headliner opened up?
I attempted to pull mine down from the back corner and from the rear of the moon roof opening, and both felt like I was going to destroy the headliner. It was sort of just folding and creasing (which thankfully went right back) without actually releasing or popping off like a firmer interior panel would.
Wichadicha
Georgia
Headliner is 80% held up by magnets, and actually quite genius. along the back glass edge there are to pop in fasteners. If you have a long pry bar you can slide it between the roof and the headliner and help pop those two down. Also, once you get one of the magnets to pop free, put a shim or something to prevent it from reengaging or your fight them all
Littlefx4
Have any pics w/ the headliner taken apart?
Wichadicha
Georgia
Unfortunately no. Assuming you have all the trim, around the area removed. Ie if you just want to pop the rear of the liner down, I would remove B and C pillar trim. Then get a little pry tool and start about 6" from the corner of the sunroom opening corner in the side. Once one of the magnets pops free you will immediately get the hang of it. If you want the entire liner out then all pillar trim, visors, etc need to be removed first.
