Towing with Supercharged 2014 Icon Stage 4?
Ruckus08
Nashville, Tennessee
Thanks Ruckus,
Is this the radiator you got?
Did you add the transmission cooler too?
Which fans did you get or were they integrated with the heat exchanger?
Those are the ones @michiganave . I also installed the AFCO heat exchanger with fans: https://www.teamjdm.com/2010-2014-ford-raptor-f150-afco-heat-exchanger-with-fans/
M
michiganave
Colorado
I pulled by neighbor's travel trailer today. The trailer is 5,000lb and I measured the tongue weight as 590lb. Power was easy and control was good. The rear squat was bad at 3 inches. We then set up a weight distribution hitch and it was still sagged 2 inches even after we tweaked. Temperatures were all fine but we weren't on any grades and it is 60s and windy today. But I could smell my front brakes which was a bit concerning! I never felt any brake fade on our short level drive. Door sticker cargo capacity says 1095lb, which we were pushing if you count the bumpers/winch plus two adult males and tongue weight.
