sportman
Hi Guys,
This is my first thread I'm very exited to buy new raptor though I have few questions regarding towing capacity..reading your great forum and searching through it seams 2012 Raptor does not tow more than 8000 pounds that's the max now just to clarify is that capable to tow the following specs toy hauler:
Jayco Octane FLOORPLAN T29A
Weights
Unloaded Vehicle Weight (lbs) 7,580
Dry Hitch Weight (lbs) 1,170
Gross Vehicle Weight Rating (lbs) 11,950
Cargo Carrying Capacity (lbs) 4,370
I'm not familiar of the above terms such unloaded vehicle weight lbs...is that the total weight of the empty toy hauler ?? if yes.. that means I'm under max towing capacity of raptor super crew 8000 lbs and technically i can load the hauler with light motor bike about 420 lbs is that will be the max I can tow by the raptor or my calculations are totally wrong needs your help before purchasing
I found out that Ford 150 (about Maximum Conventional Towing 11,300 lbs. (When properly equipped) tow more so what's stops raptor at 8000 lbs???
any upgrades modifications can be done to keep Raptor towing capacity close to normal 150??
Weights
