Torque Pro App for Android and Bluetooth OBD2
Boss327
Nor Cal
I'll let you know when my dongle comes in, should be about week.
And we'll see if I picked the right one.
The only way to know for sure is to call every manufacture out there and ask.
I see prices from $6 to $80
Does your's show trans temp? That's the whole reason I bought one and of course that's the one thing that doesn't show up.
MTF
MTF
Celebration, Florida
I'm not sure I haven't had time to play with since I made that video,
I know there have been about three updates and I saw the PIDs have changed a little.
MTF
MTF
The website for the app has alot of info, you can make custom PIDs but you need the codes for it like I mention I don't have time to play with app.
But if you post a question, Ian the programmer does answer pretty quick.
Mac
NJ
I bought the app and the bluetooth dongle. I works good with my HTC Thunderbolt. Only tried it once so far.
MTF
MTF
Update:
So here's what I found out, don't buy the cheap Bluetooth dongle made in China it can and will ruin a Tune. It doesn't have safety features built in like the real one,
It is recommended that you use the hard wire dongle OBD11 to USB and from only a certain company.
You need to research this on Torque's website.
Using the Bluetooth dongle is not as accurate and of course you have a delay with results.
As you see it says 725.1 HP at the flywheel, I know that's not right it should be more like 680.
There have been about a dozen updates for the apps since I last used it and it no longer does FWHP, it only does RWHP now.
I just ordered this http://www.scantool.net/scan-tools/smart-phone/obdlink-mx.html
Kanakry
Great Lakes Region
I used the bluetooth one for a while. Worked fine for about 3 weeks. One day on a trip somewhere my abs and brake TT's came on. Turned the truck off about 4 miles later the check engine and traction control TT's came on.
Read codes using the app and it said a network error. I pulled out the bluetooth reader and they have never come back. That was 4 months ago.
R@pt0r
Do you have a wideband Air Fuel Ratio sensor? I see the left and right bank AFR in the lower left corner. Usually the OEM O2 sensors read a small range around 14.7, but the AFR in the video seemed to have more range than that.
