Tonneau + Rack Advice
Nick@Apollo-Optics
You can add rails to a Bakflip MX4?
Nick,
What options are there for the MX4 with regards to a rack?
We can add Truxedo bed rails that will fit under your MX4 rails. The Truxedo rails will allow you to install racks or crossbars to your MX4. Just keep in mind that if you use low mounted rails, you won't be able to open your MX4 with the rails in place as there won't be adequate clearance. But it can be done!
If either of y'all are interested, please feel free to send me a PM and we can go over options.
GhostRHR
Bealeton, Va
Can you use both the low and tall towers at the same time? So you'd have use of the area undercover in the bed. Maybe a short cage/box on bars on the short stands and then kayaks on the tall stands with bars.
no that would not be stable i don't think.
OffroadAlliance.com
Boston, MA
As others have mentioned, the FrontRunner racks are great!
We outfitted this customer's truck with a Retrax bed cover, FrontRunner rack, Roam tent and a whole host of other accessories. It's a great setup. Everything has taken a real beating and held up without issue.
Let us know if we can get you setup with bed covers, racks, tents or any other accessories.
PH: 888-466-8991
Web: OFFROADALLIANCE.COM
MAMiller44
MAMiller44
Tampa, FL
Yup, Truxedo is what I was looking at using if I wanted to add one in the future. They'll fit nicely between the rails but I'm thinking I'll be good with the Decked drawers for dry/secure storage, and the space between the decked and the bottom of the rack I"m not too worried about.
Heard back from Frontrunner support today on the rails to confirm a few things:
Question 1 was about lengths: They only sell 1800mm rails that aren't predrilled. The magic number for our beds is going to be about 1675mm. Luckily they sell touch up paint so I'll be able to order the 1800mm rails, cut to size, and touch up the edge that's going to be closest to the cab.
Question 2 was confirming dimensions: True profile of the rails 45mm (1-3/4") wide by a very sleek 15mm (5/8") tall.
Question 3 was on clearance for mounting hardware: The rails are designed to be used with countersunk screws so there's minimal clearance between the legs and the track for hardware holding the rails down to clear. Sounds like this will be one thing I need to work out.
Nonetheless, Decked system comes tomorrow so that install will be this weekend. And I'll pull the trigger on ordering the Frontrunner rails to start that process as well! :D
ChrisK661
California
PH: 888-466-8991
Sweet Setup. Like the contrasting wheels. What size wheel,tire, lift.
