Just a heads up. I thought Retrax were slick until I had multiple problems with mine. They don't stand behind their product, especially their "lifetime" warranty. They want nearly $1,000 to fix their defective product. I won't be buying from them again.
I have done my research and have decided on a Retrax Pro MX bed cover.
Are their any vendors here that offer discounts, etc? Or, any other vendors that you guys recommend to purchase from?
Thx.
Can you elaborate?
Sure.
It likes to jump the track during decent off-roading which is REALLY difficult to fix (not a big deal, price to pay for fun).
The real problems.
First, the holes that the latch mechanism uses to stay totally closed are all wallowed out, so it rattles.
The eighth slat from the end gets out of place and totally binds up so you can't open the tonneau up. This makes for a LOT of fun when you have stuff in the bed (they call it "shifted slat" so they know the problem).
The "lock anywhere" function? Yeah, good luck with that over time. It's a friction lock and it's a joke. All it does is tear into the aluminum rails. Eventually you need to adjust it, which becomes impossible.
All of the hardware holding it together is crap and rust welds into place, so good luck using any of it to make the adjustments needed to fix some of the above issues.
The hardware used to retain the rails is a joke - plastic retaining stuff that strips right out. Again, preventing you from making adjustments to fix problems.
Basically, when it works, it's great. The main pieces seem really decent, but it's assembled with junky small pieces that just don't hold up. It would only take a few simple engineering changes to make it a solid product, but it seems like they cut some corners. Probably why they won't back up their product. It really is a shame, because it IS a great product at first.
Make sure you RTV (or some sealant/adhesive) the drains to the bottom of the main unit - they fall right out. You'll figure that out after the first time you have stuff you don't want wet back there and you wind up in a big rainstorm (ask me how I know).
