not cams - both sides look the same (doesn't appear to have any addons there)
No known bent items in front - Doesn't mean its not
Rear left side was hit really good Oct 2019 - however was repaired and tested for bent frame was ~20k in damage.
Real issue has been the darn shock mounts and spacers after installing rebuilt shocks..
spacer removal - incorrect - Monroe for F150 studs not long enough - grrr... my fault..
brackets not re-installed correctly a few times..
this is what it did look like when I pulled it apart...
shop had no clue... or rather - probably has more of a clue than me... but not much it looked like.
Getting the proper shock mount installed this week - and brackets correctly placed.
one on top of strut Body Mount external visible.
one on top of strut mount on the strut mount itself - hidden inside.
Still had spacers brackets and older parts - drift to the right was not an issue until I replaced the inner tie rods...
I think the original alignment was set in like your saying to compensate for some issue with all the modifications of the leveling kit or other damage unknown to me... bent ARM or something else is a good guess.
Currently bracket on top but thread not long enough to get more than 3 threads on thick side... inside bracket had to be removed to get that much thread on there.
