Jeff-Ohio
I've been concerned with this since day one. I switched to Fuel wheels and the idiots at the shop didn't balance them the right way. So I dropped $100 to have another shop double check and re-balance. I'm STILL getting a LOT of wheel hop on the freeway. It's not everywhere which makes me feel it may not be the tires. None the less, I have a shop with Road Force balances that is going to check them again and verify whether the wheels are, and can be, balanced.
I've wondered if it's because of the lighter truck compared to the '12.
Sometimes, when I nail it getting onto the freeway, my rear end and acceleration seem just plain squirrelly!
I recently started having issues with very slight vibrations and a friction, or soft grinding noise, coming from the front. My tires are balanced and rotated every 5K miles, so I thought it might be the wheel bearings, etc.... It was time to get the tires rotated again and I found out that my front tires are cupped (hills and valleys on the tires ranging from a measurement of 8 to 10); the rear tires were fine. I have 35K miles on the truck, so I'm guessing the issue is weak shocks allowing the tires to bounce slightly wearing down some spots on the tires more than others. From what I can tell, the suspension seems to be fine, but maybe not. I just put Geiser and Deaver +3 springs on the truck, so hopefully the good rear tires which were just rotated to the front remain good, but I'm guessing they will also start cupping due to what is likely a shock issue. If you have issues similar to mine, check to see if your tires are starting to cup.
