tire pressures recommended at RA
isis
PA
I’ve noticed in winter here (25-35) sitting overnight pressure and driving on the highway for 30 min doesn’t vary much. My caddy with much shorter sidewalls will swell 3-4psi even when frigid. The truck doesn’t seem to vary as much until you’re up in the 70’s
DINOZR
Southeast
Took delivery at 41/41. Bouncy AF.
Went to 38/36. Improved ride considerably.
Went to 36/34. Ride no worse. Maybe better.
Now in the cold of winter I'm at 34/33, and the ride is only better. Not gonna go any lower than this for DD.
S
saym14
Prescott AZ
Comfort isn’t everything tho. If you are cruising at high speeds or cornering hard a little more psi is better
