GEN 2 Tips to remove the lower side exterior bed plastic panels
lukeeye
Los Angeles
Hey fellas, new member here. picked up a '19 802A Supercrew.
I'm trying to safely remove those odd-grey colored plastic pieces along the bottom of the truck bed behind the rear wheels. I know there are three pop pins underneath, and a number of expansion pins in the hidden back side, but are there any additional lock pins or screws I need to be aware of? Can it be removed without messing with the rear wheelwells? Any tips would be appreciated-
Thanks in advance for your help...
Kahuna
THE MORE YOU PLAY WITH IT, THE BIGGER IT GETS
All the pins that need releasing you can see. Don't bother doing the blue ones, they are for the fender flare. Start at the back and work your way forward. There is a line of double sided tape along the top edge which needs peeling off. You can slip it out without messing with the flare.
