Nice, I like it! Dumb question maybe, but I wasn't sure, the spray is applied to the outside, correct?
You sir are correct.
Does the spray come in a "rattle can" that you can buy at a local auto store?
Did you have to do any prep work before you sprayed?
Washing and then wiping with some alcohol is a given... what I mean is, did you have to use some steel wool or something to roughen the plastic up first so that the nightshade would stick?
Is clear a must? I was advised that the clear can expose any unevenness with the coats of VHT Nightshades.
Does anyone have a close-up of what the circles look like (without the brakes on) after the Nightshades is applied?
