Raptorguy21
The Bob Vila of Trucks
At least all your LED's are working.......
if you have leds that are not working just pull the affected one and check the wires on the bulb. i had to bend mine so they would make contact in the rubber housing.
Iron, The company Im getting the projectors from is moving locations and will be back in business on the 31st, so if you order between now and then theres a 10% discount, this is the projector I will be using, about $100. - Bi-xenon: Morimoto Mini H1 4.0 - HID Projectors from The Retrofit Source Inc Theres a cut off shield that moves away when you engage high beams. So basically the halogen high bulbs on the inside never come on, the projectors are your lows and highs, which is much better for the xenon bulb life because it is always on. Plus you have HID for low and high. Ill find some pics of the cutoff's.
Im almost done with mine, its not as hard as I thought it was going to be.
