Things to check after taking delivery
rp606
kentucky
It’s in the 20 degrees out here, is it ok all tires are in 40’s psi or should I lower it to recommended cold 38 psi?
stoppard stop
Manheim, Pa
I would lower it. If its 20 degrees and theyre at 40, when it warms up, say to 60, then the tires will have even more air in them. Personally id go down to 34-36 in 20 degrees
TXAG
Just got around to checking my fuse box, and they all needed to be pushed in like reported. Surprised to find this considering it's a more recent build. I need to get under it pretty quick and check some of these other things out
sacramento
This thread has been helpful so thanks everyone for sharing. My aux 1 switch does not turn on the off road fog lamps, am I missing something or should it be set up to work right out of the factory? Guessing I’ll have to have the dealer check the wiring.
Littlefx4
Check your engine bay fuse box. Make sure they’re pushed all the way in. Willing to bet cha someone’s gonna ask did you remove the covers. Lmao
Oggie
California
I think aux 1 controls the fog lamps with the rigid covers. To turn on the outer (uncovered) fog lamps, press the round dial that you use to select a light setting.
sacramento
Thanks, I had a look but everything seemed secure. Ahh well, considering I have had no other real issues so far except cosmetic damage during transportation, I can drop it off to the dealer and I’m sure they’ll get it fixed pretty quick.
Haha yea I was waiting for someone to chime in with the cover removal, the ironic part is I have had my truck a week and only got around to testing them now because I was thinking of getting some of the amber tinted covers so wanted to see what the double white stock fog lights look like in person first.
Keshka
Summerville, Oregon
We are right in the middle of a cold snap and temps outside are around 5-15 degrees. Have not had any inclination to do a detailed inspection. I can tell you that I have NEVER purchased a new car/bike or truck that did not have details that needed taken care of. So far, I have found nothing in casual inspections. Maybe as stated earlier may be the Code Orange Metallic (grin)
2010 RAPTOR SVT
West Michigan
Checked the fuses today after a Gremlin issue yesterday. Sure enough, everyone of them in the panel in engine compart needed to be pushed in. I also have stress cracks in left front fender. Still waiting to hear what Ford is going to do.
