So recently did some maintenance on the truck and saw the rear pinion seal starting to leak. Well then thought I’ll change the fluid at the same time as the seal. Then add the Foutz pinion guard/diff guard. All well and good except there’s a Mag Hytec cover on the diff and will need to be changed to stock or the Spicer cover = snowball effect lol
I then grabbed the other items off the shelf which were in line for mounting and laid it all out. Let the fun begin. Hopefully will get to all of this by the end of the month and the Mag Hytec on the block.
