TaylorF-150
- Joined
- May 10, 2016
- Posts
- 327
- Reaction score
- 227
Not sure if you've tried it or not yet, but since you seem to like painting stuff, you really should finish off your parts with a 2K clear for it to last and look the best. 2K = 2 part = paint with a hardener in it. You can sand it and polish it to a perfectly flat shiny finish too.
The cans are expensive, but well worth it.
https://www.amazon.com/dp/B0082LJMC6/?tag=fordraptorforum-20
2 part paints with hardener require a respirator while spraying, but a good 3M mask for organics is only $30 or so. The spray from those Spraymax 2K clear cans is unbelievably smooth, a nice fine fog. It's only good for a day or so after you activate the hardener in the can, so make sure you have enough stuff lined up to paint with it. One can will paint a surprising amount of stuff, even with multiple coats.
If I was the one painting stuff, I'd give that a try, but I suck at that stuff, so I've been leaving the painting to the pros!
