The "Official" Snoball Prep GROUP buys
SilentShooter
Siesta Key, FL
Specs on 3/4" D-Ring
Black Coated D-Ring Shackle, 3/4 inch
4.75 Ton weight rating
Cast Steel Construction
Is that its WLL or max? If max I'll pass on them.
---------- Post added at 08:07 PM ---------- Previous post was at 08:06 PM ----------
Man Roger, you will just take anyone's money.
Well some people will give their money to anyone...
IRONMAN
Well-Known Member
MICHIGAN
I believe that's max.
Smittybilt Part 13047B - 3/4 inch D-Ring Shackle, Black Finish - 4 Wheel Parts
I can get these.
$38.00 +shipping
WARN 3/4" inch D-Ring Shackle
images.ashx
-For winches rated up to 18,000 pounds
-Cerakot coated
-7/8 inch pin diameter
-Shackle pin is threaded to allow easy removal
-Connects looped ends of snatch blocks
This forged steel clevis shackle provides a means for connecting the looped ends of cables, straps, and snatch blocks. The shackle's pin is threaded to allow easy removal. For maximum protection against wear and abrasion, the premium shackle uses Cerakote coating. All WARN Premium Accessories feature Cerakote coating. This state-of-the-art coating provides a durable, weather- and corrosion-proof, ceramic-based protective finish that resists scratching, chipping, and abrasive cleaning solvents.
IRONMAN
Well-Known Member
MICHIGAN
