ah I see the that radius bend in the front 40" you're talking about, so it matches the upper. Very clean looking! If you were able to keep that part, but just angle the outer edges up after that middle 40", thats what I'd really prefer. Then the center plate should be identical to that one, and just the outer parts of the lower tube changed. I see how those outer lower portions of the tube do flow with the curvature of the fender flare, but since it's drastic different materials from plastic wide flares to thinner tubular metal bumper, I think you can still keep the end of the tube lining up with the fender flare, but bending it towards the center sooner and at a sharper angle. It somewhat replicates the more angular-ish shape of our factory fog openings.
A very ROUGH paint photochop of what I'm thinking, and maybe not at this angle exactly, but between this and the original is what I was thinking.
