Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
Dude that is the pressure relief regulation port. Since the truck is aluminum, gas build up due to a reaction. If that gets plugged it could cause the tailgate to swell and it will not open/close. Check your doors, you have similar relief holes at the bottom. They do not cover it under warranty if they can prove you plugged it. True story
I used it to open the tailgate when the electric motor stopped working. Had to make a tool to get in there to access the mechanical part of the release assembly. The tool looks like a distributor wrench. I keep it in the truck in case it ever fails again.
