Yes it shows both. I'm just used to it showing the RPMS digitally. I guess the 2024's dont have that optionisn't it showing you both - the rpm's on the outer circle and the gear in the center?
This is really a problem. For a sport truck that does 0-60 in 5.2 seconds, not to mention all the other performance stats, and with a 140 MPH speedometer, it should have a tach that shows detailed RPM readings.2024 Raptor R Out of the blue my tachometer starting showing the gear the truck is in instead of the rpm's. Any ideas?
When you say you are "used" to it showing the RPM, are you saying your 24 did or that you had a previous year model before the 24? @gtbuzz34Yes it shows both. I'm just used to it showing the RPMS digitally. I guess the 2024's dont have that option
I honestly think that the shift light and and the HUD are better than a "detailed" rpm readout on the instrument cluster. Although it is kinda silly to have the gear indication twice on the screen.This is really a problem. For a sport truck that does 0-60 in 5.2 seconds, not to mention all the other performance stats, and with a 140 MPH speedometer, it should have a tach that shows detailed RPM readings.
I'm surprise that on this forum, no one has anything more than a "guess." My Raptor, less than 600 miles, came this way from the factory, and I have tried to either find a solution in the manual, use tech common sense with the dash controls and features, or search the internet. Nada.
