So I've found some anecdotal evidence that using a switch on the ground leg of a device isn't the ideal choice, but it's feasible. I wanted to throw out to the greater group what they think of this.
Here's the scenario. I'm adding more lights behind the grill and I'm out of Uplifter switches. If I run these new lights off of a set of new switches, to do it right, I'd need to add in some fuses and relays and lots of wiring.
One option that I can think of is this. If I accept the fact that the amber lights I'm installing behind the grill will NEVER be on without also having my Rigid Amber Fogs on, I can wire the hot lead for the behind the grill lights to the Rigids and run the ground into the truck cab, into a switch, and then to ground. When I interrupt the ground on the grill lights, the Rigids will remain on, but I'll be able to control the grill independently in a way. This also reduces the number of wires I run into the cab. I don't run a load through the switch if I ran straight from a hot source and I don't go through the effort of installing and wiring a series of relays.
I know it's not the "right" way, but I'm okay with that!!! Any reason I can't leave a load on a device (light) and just interrupt it's ground for on/off?
Thanks in advance.
Todd
Thanks in advance.
Todd
