GEN 2 SVC OFFROAD Gen2 Bumpers in stock with free Same day shipping!
xrocket21
Maine
Same! I just don't wanna cut my frame.
The non frame cut bumpers stick out to much in the front though.
I don't mind cutting the bumper, its just the total cost of the bumper + the IC that stings. It looks so friggen sick though. If you go with the one that holds lights, plus the cost of the lights, plus the cost of the IC, its some serious cheddah!
svc
svc
Worldwide
@svc Free shipping promo still on?
I do not want to cut my frame so only the bolt on will fit with no cutting?
I’m ok with an intercooler if I don’t have to chop the frame.
Thanks!
Free shipping is still on! Bolt on is currently in stock as well , intercooler is not needed but it is also in stock.
---------- Post added at 08:27 AM ---------- Previous post was at 08:24 AM ----------
I want a smurf bumper so friggen bad!
In stock and ready to go with free shipping !
xrocket21
Maine
Best bumper out there IMO!!!!!!!!!!!!!
zombiekiller
OG BooBooRunner
New Orleans
any detailed pics/instructions on the amount of cutting required?
The orange lines are the cut lines. Here are some reference points:
where the yellow circle is, on the top of the rail, there is a square with a nutsert in it. That nutsert is used for the lower IC mounting bracket. you cut just in front of it.
you come straight down, then follow that angle.
Run the cut lines with masking tape, so you can find an index point on both sides to make it match.
Then cut straight across the bottom.
Where the red circle is, you'll trim the "ear" off of the body mount and grind is flush with the frame rail.
As an fyi, if you are running remote resi coilovers, you will probably have to grind down the resi front mounting bracket so you can still bolt it on. ( because there is now an additional thick piece of metal between the nutsert hole and the framerail.
I'm sure SVC has more pervasive instructions out by now, I'd just call them if you need a step by step.
TXRaptor
Installed on Friday!
You need to jump your truck again so you can get an up-to-date Avatar picture with your new bumper!
Seriously, that is one of the best looking non-frame cut bumpers I have seen... :biggrin:
