SVC Bypass Rack
LONGISLANDRAPTOR
Long Island, NY
Hey guys. This might be a dumb question but here it goes.
I have Deaver springs and stock shocks. Recently I had my stock shocks out and was expecting the deavers to droop way down but they did not. I actually had to push down on the springs to remove my shocks. My question is how dose the bypass rack gain so much down travel if the springs don't droop out any further? Do the shocks push down the springs? And also with this kit do you need to relocate/ lengthen the rear brake lines?
svc
svc
Worldwide
Hey Mike,
As for the brake lines , you will need extended lines to account for the added droop. I would also check the torque setting on you rear shackles as well since these should be able to droop freely.
-Jeff
LONGISLANDRAPTOR
Long Island, NY
Ok cool thanks. Maybe a set of poly bushings in the schakle will help. My spring will droop all the way but to get the shock out I have to push down on the wheel skittle more
Huck
Chicago Sw Burbs
The shock doesn't push on the spring it just dampens (slows down) the movement. Shock has no bearing on ride height
LONGISLANDRAPTOR
Long Island, NY
Yea that I know thanks Huck. I was just curious how you gain the down travel if the springs don't droop down after shock removal. Mine and other trucks I have had the rear shocks out of, the rear end has to be pushed down to remove the shock. It dosent just fall down when the lower shock bolt is removed like I expected
m3dragon
Orangevale
In a recent pre-run I pushed the truck harder than I normally do. Let me say I took some hits I could have swore were going to brake something. Instead things were all in place and no issues. Survived 160 miles of dirt and then another 130 paved miles to get home.
Short recap but I can attest to the durability of the dual front and rear setup.
