Stoked!
GordoJay
Colorado
+3 with extended shackle sits at stock height
+3 with stock shackle sits 1 inch taller than stock
+4 with extended shackle sits with 1" of lift
Extended shackle coupled with longer shock will give you more droop travel
Rumor(since no one seems to be able to confirm it) is that +3HD sits 2 inches higher than stock when unloaded and +4HD sits three higher. I guess that way they sit the same under designed load as the regular +3 and +4 do with no load.
Bowewelding
+3 sits 1 inch higher than stock with stock shackles they say..although with a 2" extended shackle they sit at stock height
Ron Lanza
Newnan, GA
I may get hammered for this but. Whats the difference between 1'' taller then stock and 1" of lift ? I just put Eibachs on my 2020 SCAB and the front sits slightly higher then the rear. What can I do to bring the Ass end up 1/2" to 3/4" but no higher ?
Bowewelding
I ran +2 deavers before my current set up and it sat pretty much stock height. I had eibach coils and the +2 and the front still sat a little taller. Deaver claims the +3 is 1" of lift meaning 1" taller than stock
GordoJay
Colorado
No difference. Just a less repetitive way to say it. You need Deaver +3s or the Icon rear, don't know what setting, probably 2.
