onesickpuppy
Welllllll, since we have ya Fox dudes on board, I am a bit curious on our stock valving for front and rear and Comp and Rebound? I was accustom to revalving Fox shocks a few years back and understand the by-pass as I used position sensitive outer by-pass shocks in conjunction with straight valved shocks, as well as Yamaha and White Bros shocks. I do not have my truck yet, so I cannot check on my own, which I would. Some questions are; what is Comp and reb (80/60) for instance for front and rear, what size, if at all are the bleed holes? I do want to be able to tune the stock shocks for if I feel too much kick or stacking. I still have shim box and charts from past life with sahft seal, O-rings, shrader valves and such.
Question 2; At some point I will go with a bump stop in the rear. While I like air for stops does this cause a kick or can the rates be changed on air stops, or should I go with oil type stops? I fyou cannot tell I hate kick in rear, I like it to hold down a bit and also lightens front to stay up some.
Any information is appreciated.
OSP
OSP
