GEN 2 Stock length LCA options
Aesconde
How are you liking the setup?
I love the setup. The dual bypass makes a big difference over stock or the fox factory coil overs. Ideally, I would have wanted to go mid travel but don’t have the needed disposable income for it.
K
ksgries
Phoenix Az
Any options for limiting straps and bump stops?
Yeah my wallet has no interest I spending the money on a mid travel, maybe if I let was strictly an off-road toy and I didn’t care about what I put it through lol
Aesconde
Not sure about the bump and limit straps.
K
ksgries
Phoenix Az
I got in touch with someone, no limit or bump stop mounts unfortunately, not a huge deal. They didn’t answer some of my questions though.
Is the upper mount to the secondary shock weld on or bolt on? Did you have to order the shock separate?
Aesconde
Check out camburgs new lower if having a bump and limit strap is a deal breaker for you. There’s new photos on their Instagram.
The rpg secondary mount is weld on. It’s three pieces see pic below. The shock was in stock when I got my lower.
Rednose
Dubai
Bummer now any weld to the chassis would disqualify my truck for being registered.
I really wanted that lower arm to add a secondary shock.But I guess ill have to check with Camburg or Baja Kits also. for a bolt on option.
jeffraptor
houston
Did you do the install yourself or have a shop do it? Could you post more pictures of your front suspension set up? I am interested in doing the same.
