Stock front bumper v.s. aftermarket?
C
Cody Templeton
Des Moines, IA
The front frame horns are definitely cut down to fit that bumper, just compared my stock truck vs the Raptor. If I got a stock front bumper bumper and the SDHQ winch plate I'd have to weld on new front frame horns, so it may just be better to stick with this setup and modify it. Are all the aftermarket steel bumpers done this way or is it just the pre-runner bumpers? It definitely seems like with cutting them back you get much more reinforcement.
C
Cody Templeton
Des Moines, IA
Are there any pre-runner style front bumpers that allow a winch? I'd like to have one, but if I can't with a cut front end I'll just have to go without it.
PorterW1111
Florida
You can put a winch in that bumper...
You’ll need to cut a slot in the skid and build a custom winch mount. Also going to need to do some research on specific winches since you’ll need the one with the most power and the smallest size.
there is still a ton of room behind that bumper. You will just need to measure 1000 times and get a mount fabricated...
PorterW1111
Florida
I just went out and looked at mine. The only thing that you might have to get creative with is the trans cooler lines. May need to extend them to go around the winch.
but definitely plenty of room
C
Cody Templeton
Des Moines, IA
everything done to your truck so far is not recommended by ford.
This is a little different, you're cutting or welding onto an extremely structural piece of the truck. I think the reason is because it was heat treated and doing such would weaken the frame. We are talking lots of drilling and welding to mount a set of rock sliders on a supercrew truck.
PorterW1111
Florida
this is your bumper thread lol. im talking about a winch mount for your bumper...
that being said welding to the frame arguably only makes it stronger.
C
Cody Templeton
Des Moines, IA
I was talking about doing rock sliders, the front of the frame isn't where I'm worried about. Either way I'll have to do some custom work it seems.
